Best firewall passage
Old Oct 30, 2004 | 12:49 PM
mikejr1981's Avatar
mikejr1981
Lightbulb Best firewall passage
I have a 2004 Ranger and will be needing to send wiring through the firewall
for fog lights and stereo, equipment, ect. What is the best way to get through
the firewall without a lot of modification.
Old Oct 30, 2004 | 07:08 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
You should be able to find a stock hole that you can fit a few wires through, take a look under the dash or on the firewall.
Old Oct 31, 2004 | 01:59 AM
grease monkey's Avatar
grease monkey
I ran my amp wire through the hole where the steering box goes through. There is a rubber boot there just poke i little hole in it and run your wire it will go under the dash.
Old Oct 31, 2004 | 11:09 PM
maticuno's Avatar
maticuno
I ran my wires through the little grommet around the clutch. Easiest way to do it is to get some bailing wire and use it as fish tape.
