Minor Jerking.....
Old Oct 30, 2004 | 10:31 AM
90F1505.0L's Avatar
90F1505.0L
Minor Jerking.....
I have noticed some minor jerking(missing?) in the motor when the RPM's are 1500 or less. I just replaced the TPS a couple of months ago and I am thinking that it might be the voltage. thanks.... by the way it is a 90 F150 5.0L
Old Oct 31, 2004 | 01:09 PM
clark714x4's Avatar
clark714x4
Any codes??
Old Nov 1, 2004 | 08:19 AM
90F1505.0L's Avatar
90F1505.0L
No codes at all....
Old Nov 1, 2004 | 09:46 AM
corpsedub's Avatar
corpsedub
this type of bucking occurs in the 300 six too. right around those same RPMS. some people reported that replacing the throttle body gasket relived this issue. it seems the stock gaskets on these years tend to get weak and let additional air past the throttle.
Old Nov 1, 2004 | 10:21 AM
clark714x4's Avatar
clark714x4
Could be a vacuum leak in the lower manifold gasket or the throttle body shaft seals. 90f150.0l, do you have a plumers propaine torch? They are cheap if you don't. use it unlit in these areas and see if your rpms increase.
