2000 Expy Trans Problems
Old Oct 30, 2004 | 10:29 AM
Castor's Avatar
Castor
I have a 00 expy, and occasionally the transmission will go absolutely beserk, such as not engage at all, or slip in low and reverse, fine in high range. Or it will make a noise in low and reverse (sometimes not always). It may not engage at all, then a few minutes later it may. Or it may be fine for months, then it may start all over again. It shifts into 4wd and low4wd fine. Any one with the same problem?
Old Nov 2, 2004 | 08:41 AM
99ExpeditionXLT's Avatar
99ExpeditionXLT
Things to Try
First off how's your fluid level? Slow shifting, or not shifting at all are symptoms of low fluid. The 4WD shifting you mentioned is not related to transmission shifting, it's more of a mechanical function. If your fluid level is fine, you may try some cleaning fluid, or changing fluid along with the filter (cheaper fix). You wont remove all of the old, but if you experience improvement, you may consider a transmission flush and change at a shop.
DieselBurner153
Mar 26, 2013 12:18 AM
5.0 Heaven
1978 - 1996 Big Bronco
Feb 12, 2013 07:21 AM
giants17068
May 23, 2012 10:12 AM
tofer76
1997 - 2003 F150
20
Aug 23, 2011 11:27 PM
masterP
2004 - 2008 F150
Jan 10, 2005 02:34 PM
