F150 Front Axles
Old Oct 30, 2004 | 09:59 AM
DanLF150's Avatar
DanLF150
F150 Front Axles
First time user! Don't know if I'm in the right place but here goes!
I am replacing my front axle outer u-joints on my 1996 F150 4X4. Do I have to remove the spindles at the ball joints to do this? And do the axles just "snap" out from the diff housing?
Thanks for anyones help!
Old Oct 30, 2004 | 01:21 PM
SRD4X4's Avatar
SRD4X4
Pull the spindles'leave the knuckle axle slides right out
Old Oct 30, 2004 | 01:24 PM
SRD4X4's Avatar
SRD4X4
Remove clamp on right side slip joint
Old Oct 31, 2004 | 07:35 AM
low-side's Avatar
low-side
You'd be better off dropping the front diff, pulling the c-clip an ddoing the inner u-joint on the right side also. That way you get the inner joint, can replace the seals, and drain the dif at the same time.
