Help! Won't start!
Old Jul 1, 2002 | 03:47 PM
mikejeepers's Avatar
mikejeepers
Help! Won't start!
Old Aug 29, 2002 | 08:49 PM
Pilgrim's Avatar
Pilgrim
Help! Won't start!
91 3L 5spd. Only clicks when I try to start it. Good battery and connections. Relay(solenoid) is good. Any help?? Thanks in advance.
Old Aug 30, 2002 | 03:10 AM
Mauser8mm's Avatar
Mauser8mm
Help! Won't start!
Sounds like your starter went bad? Im not exaly sure, have it tested at a autoparts store. Good Luck!
1979 F-150 4x4 351M C-6 NP205
2001 Ranger XL
Old Aug 30, 2002 | 08:37 AM
Ken00's Avatar
Ken00
Help! Won't start!
Did you have the battery tested, make sure you do that before testing the starter, easier to take out.
Old Sep 9, 2002 | 05:44 PM
Dutch147's Avatar
Dutch147
Help! Won't start!
[updated:LAST EDITED ON 09-Sep-02 AT 06:45 PM (EST)]
Same problem as the start of this string, only thing is, I replaced the starter relay and the starter. I did this maybe a week ago. Now I have the same problem as before. It just goes "click". I know that the battery is good, the starter better be good (it's brand new and so is the starter relay). Could it be anything else? I have the Haynes manual, but it was wrong last time. I don't think that the relay was bad.
1993 4.0L 4x2
Old Sep 9, 2002 | 07:37 PM
Dutch147's Avatar
Dutch147
Help! Won't start!
Turns out that I had a loose connection. The ground lead on the starter was tightened down, but the washer was too big and not making the connection properly. I wish I hadn't pondered over it so long. I like it when it's an easy fix.
