OW My headers hurt!
Old Oct 29, 2004 | 04:58 PM
jamiesan's Avatar
jamiesan
OW My headers hurt!
1st the good news: my Hedman Elite headers & true duals are on my 95 flareside. So is my 4" suspension lift! BONUS! Now the bad news...The new angle of my front drive shaft causes it to grind on my reducer flange on driver's side!!! The only thing I can come up with is to make a wedge shaped flange adapter where the headers meet the head.( Fat at the top, 1/8") tapering down to like 1/32" at the bottom side. Does any one have any other ideas on correcting this? How about a good HI-temp sealant capable of handling header temps?
Old Oct 29, 2004 | 07:18 PM
huskyhauler's Avatar
huskyhauler
just on the flange? if so i would have a new piece of pipe welded on the the collector pipe to move the flange out of the way. i have run into the same situation on the early (80-86) f series and broncos. always has a step made from the 2.5 or 3" down to the desired pipe, weld it to the collector pipe, and put the flange at the end of that. hope that helps..
Kurt
Old Oct 30, 2004 | 07:16 AM
jamiesan's Avatar
jamiesan
I mean the flange at the top of the headers, where it meets the cylinder head, to offset where it comes down. How about a hi-temp sealer?
Old Oct 30, 2004 | 07:45 AM
fefarms's Avatar
fefarms
It is difficult enough to get headers to seal and stay sealed at the exhaust ports stock out of the box. Modifying the flange, inserting wedges, high-temp sealants, etc. seem like a very distant and undesireable last resort. Exhaust gas temperatures at the ports can approach 2000 degrees.
Surely there is an easier way to mod the headers at the point of interference.
Old Oct 30, 2004 | 09:04 AM
moose94's Avatar
moose94
2000 degrees? Holy crap batman. Are they shorties or long tubes?
Old Oct 30, 2004 | 12:43 PM
huskyhauler
uh 2000 i think is a little high. your headers would more likely take about 2-3 heat cycles at that point than turn to glass, and shatter. is it hitting the flange or the header pipe? i thought it would be alot easier top moodifiy to collector pipe at the bottom than to mess with the flange. thats a bad idea, gaurantee they will never seal again..
Old Oct 30, 2004 | 05:08 PM
F150'89's Avatar
F150'89
A hot rodder that I know uses Ultra-Copper silicone sealer on his header gaskets.
Old Oct 31, 2004 | 12:55 AM
Eric C.'s Avatar
Eric C.
If it's rubbing on the flange at the collector take it to the exhaust sop and have them cut and move it. As mentioned befor adding spacers or fancy shims is asking for a leak and other problems.
Old Oct 31, 2004 | 11:47 AM
huskyhauler
thank you eric c..
Kurt
Old Oct 31, 2004 | 01:58 PM
jamiesan's Avatar
jamiesan
They are long tubes. Hedman Elites. They have a spherical collector that mates up with the reducer. The two triangular flange couplers ( with 3 holes each) are what is rubbing my drive shaft. Cutting or modifying the collector??????? These are HTC coated and can't be welded on. PITA!! Any way on Monday I'm gonna make the wedged shim/gasket out of copper at work, I'll let you know how it turns out.
Old Oct 31, 2004 | 03:40 PM
huskyhauler
i would have just cut enough collector off to remove the flange, ground some of the htc coating off with a 3m or wire wheel. and welded an extension on. paint it with some matching HT paint, and been done. i like the htc coating. but even in the salt belts,the headers never last more than 4-5 years. usually the flanges warp before they rust through, even the 3/8" flanges..
Kurt
