I was buying a new flasher for my truck. I noticed that one was electric (clear housing with gizmos inside) and the other was thermal (silver ?aluminum? housing). I could visualy see how the electric one works, no brainer. But how the heck would a thermal one work?
i figured a engineer would jump in and tell us about thermo heat build up at the copper tip causes resistsants in the disculmbobulator while flashing at a numeriatic rate.......oh welll i guess it was just to simple for them..to make it too hard to understand..... . ....
If I wanted to put turn signals on something that didn't have them, all I would have to do is, take a wire from the battery to a swich to a flasher to the light, Right???
And as you add lights the flash rate changes (speeds up). Reason being more lights, usually wired in parallel, will draw more current. As the current increases the the thermal element heats faster and increases the flash rate. Most noticeable when you hook up trailer lights.
