2002 expl. front end noise
Old Oct 28, 2004 | 09:45 PM
RA81222's Avatar
RA81222
My 2002 expl. has 59,000 miles on it. It started to make a loud humming noise when turning left. My tire tread was geting low so I replaced them for the winter with same style tire but still have noise when turning left. I do feel a slight vibration in steering whell when I hear the noise. Any help??
Old Nov 4, 2004 | 04:19 PM
LV Dan's Avatar
LV Dan
Is the humming coming from your power steering pump? Or is the humming sound like rubbing noise? If your power steering pump is causing the problem, it should make the sound when you steer left even if the car is not rolling. So have some one listen to the engine to see if the noise is there while turning the wheel.
Brakes and/or wheel bearings might cause the noise as well, but the car would need to be rolling to get noise from them.
Old Nov 4, 2004 | 08:57 PM
RA81222's Avatar
RA81222
noise/problem solved
took car to dealer. they found right front wheel bearing bad. I guess they had to replace whole hub assy. since it has sealed bearing in it.thanks
Old Nov 5, 2004 | 11:17 AM
chazglenn3's Avatar
chazglenn3
I think my 2002 Explorer has at least one bad front wheel bearing...what did the repair cost you? My Ex has 95,000 miles on it.
Old Nov 5, 2004 | 03:19 PM
LV Dan's Avatar
LV Dan
If you have 4WD, the hub at the dealer will cost $265, plus $15 for a new axle nut, plus 1.4 hours of labor. The OEM or aftermarket hub is $175.
If you have 2WD, the bearings can be removed and should cost considerably less. The labor will be about the same.
Old Nov 5, 2004 | 06:44 PM
chazglenn3's Avatar
chazglenn3
Ouch! Of course it is 4WD. Thanks!
Old Nov 5, 2004 | 11:00 PM
RA81222's Avatar
RA81222
repair cost
total bill was $360.00.part was $183.00and labor $157.00.This was done at dealer.
Old Nov 6, 2004 | 09:53 AM
chazglenn3's Avatar
chazglenn3
That is much cheaper than the price LV Dan quoted, unless you have a 2WD Explorer. Thanks!
Old Nov 6, 2004 | 09:20 PM
RA81222's Avatar
RA81222
I have 4x4!
