differance between 1 @ 2
Old Oct 28, 2004 | 08:52 PM
t.j.g.'s Avatar
t.j.g.
this is a lame question but at the filling station one pump will be labeled #1
and the other nozzel labeled #2 the #2 is about 15 cents more
i hope the #1 wasnt dyed fuel ?
if so i just filled my truck up with it.
or is #1 winter blend and #2 regular diesel
thanks for any reply
Old Oct 28, 2004 | 09:04 PM
oppy's Avatar
oppy
You want the #2.
#1 is lighter, more like kerosene. It has less energy and lubricity per gallon than #2. It won't really hurt anything, but you're dollars ahead by using the #2.
In the winter here in the frozen tundra, some fuel suppliers sell blended fuel, which is a mixture of #1 & #2. Other places sell a #2 product with special flow additives. The problem with #2 is that it can gell up in extreme cold weather and cause your engine to stop running. You may have seen a semi sitting on the side of the road on one of those really cold below zero days - many times that's because of fuel gelling.
You really won't need straight #1 in the winter unless you're way up north in Canada or Alaska.
Cold One
6.7L Power Stroke Diesel
21
Feb 29, 2012 08:02 PM
nodakford
23
Jun 7, 2006 12:32 PM
knight60626
18
May 23, 2006 09:23 PM
F2FIFTY
Feb 10, 2006 10:05 PM
cmcnabb
Nov 22, 2004 01:21 PM
