new engine computer
Old Oct 28, 2004 | 08:49 PM
mike L's Avatar
mike L
new engine computer
How long does it take a new computer before it can start read codes, for memory and key on not running?
Old Oct 28, 2004 | 09:10 PM
EPNCSU2006's Avatar
EPNCSU2006
How long before it recongizes a problem and sets a code? Shouldn't take too long, just a few miles of driving. KOER should show up as soon as you run the test.
Old Oct 28, 2004 | 10:18 PM
fefarms's Avatar
fefarms
There won't be any memory codes until you have successfully started the engine at least once.
You should be able to get the 1-1-1 pass code on the first power up, by turning on the key with the STI jumper in place.
Old Nov 9, 2004 | 10:02 PM
mike L's Avatar
mike L
Putting in a new eec
Hi guys finally got my rebuilt eec! The direction said to remove the ground from the battery and something about static electricity can fry the EEC. Whats the correct way to put this in correctly( static????) ? Also should I remove the poss. cable off the battery to? Thanks guys!
