390 Rods
Old Oct 28, 2004 | 06:19 PM
pcullins's Avatar
pcullins
390 Rods
Does it matter which way the hole on the piston end of the rod faces
Old Oct 29, 2004 | 10:57 AM
Mike G's Avatar
Mike G
The oil hole for the wrist pin is on the same side as the cylinder wall oiling groves on the crank caps (V-shaped channel where the caps come together). These are to point to the center of the motor or toward the opposing cylinders. The pistons will have a notch or V on the top at one side, that points to the front of the motor.
--Mike
Old Oct 29, 2004 | 01:27 PM
pcullins's Avatar
pcullins
Thanks Mike.
Phil
