Interesting problem after rebuilding carb
Old Oct 27, 2004 | 09:56 PM
notyettoday's Avatar
notyettoday
i just rebuilt (my first time) a holley 4160 carb. well, i went ahead and put it on my truck (79 f150 w/460) and theres a tube in the middle of the barrels on the primary and secondary side. when i'm turning the truck over, gas squirts out of the tube near the secondary side. its a wide tube probably about 3/8ths id, and gas squirts out at an alarming rate. any clues? i'm totally stumped
Old Oct 28, 2004 | 01:15 AM
big hoss 29's Avatar
big hoss 29
I had the exact same thing happen to me 2 weeks ago on my Holley 4180. When you put the fuel rail on the carb, you have to be careful not to rip the little O-ring on the rail. I had a few other problems with the carb after I replaced it, but I went ahead and got an Edelbrock 1406 and I'm a lot happier with it than the Holley.
Old Oct 29, 2004 | 06:19 PM
LxMan1's Avatar
LxMan1
You talking about the tube sticking up on top of the carb? Those are bowl vents. If it is coming from there, then either the float is adjusted way to high or there is a small piece of debris in the needle and seat.
crazyeddie
Aug 5, 2010 09:35 PM
F-250 Ranger
May 16, 2010 09:28 AM
Dyerstown
Dec 20, 2003 07:02 PM
Seifferlein
18
Jul 22, 2003 09:18 AM
