Crank/cam install
Old Oct 27, 2004 | 06:11 PM
kwing's Avatar
kwing
Question Crank/cam install
I am wondering why the books call for installing the crank and pistons before the cam? It is easier to guide the cam through the bore while I can get my fingers on it. Any thoughts??
kwing
Old Oct 28, 2004 | 09:29 AM
Mike G's Avatar
Mike G
Cam goes in first on the FE engine rebuild...
--Mike
Old Nov 10, 2004 | 01:57 AM
deerhunter3814's Avatar
deerhunter3814
I run 429/460 engines, and I always install the cam first for the same reason, it helps to keep from banging and scaring the cam bearings when you have your hand on the cam shaft to guide it thru the cam bearings. I will continue doing this untill someone smarter than me can explain why the books way is better.
Old Nov 11, 2004 | 03:31 PM
kwing's Avatar
kwing
Wink
Yeah, I installed the cam first. The engine is back in the truck and purring like a kitten. Thanks.
kwing
Old Dec 17, 2006 | 08:44 AM
Limonator460's Avatar
Limonator460
FE Motor rebuild help
I am rebuilding a 390, took it all apart and trying to find an exploded view of the timing setup. I normally do SBF and have not put an FE together in a while... just drawing a blank on everything under the timing cover, such as the fuel pump drive, spacers and covers. No use in screwing up new parts and doing it over later.
Thanks for any advise or help
