Hey everyone. First time post here. I have been reading about the superchip tuner for a few days now and finaly decided to get one. Mine should be here in a few hours as soon as UPS shows up.....I can't wait.....Anyway, I saw a post last night where one member posted his custom settings for shift points and shift pressures. I thought it would be a good idea to start a thread that had everybody's custom settings for their trucks to take a little of the guess work out of the abilities of this tuner. Dont forget to post vehicle type and engine. I have a 2004 screw FX4. Just got it last week...... I'll post my custom settings after I play around with it for a few days....
mine is set on 97 mode but i would like to change shift pressures and rev limiter these ideas you are looking for would be very helpful to everyone with a tuner
I now have mine and must say that I love it. I like the superchips settings but the shift from 1-2 is a little rough.
Does anybody know what the superchip setting is for this shift point. When I am in the menu for the this adjustment, the screan reads superchip setting. If I use the right arrow, nothing happens because all the way to the right is the superchip setting. When I use the left arrow, it begins and "Stock +20 psi" and reduces by 2 psi every time you push the left arrow. My question is, is the superchip setting at +20 psi. If it is, then is will probably set it at +18 psi. But if the superchip setting is at say 12 psi, then I don't want to increase it. I think you all know what I am getting at.
I also found the superchip setting a little harsh for that shift. I started at the other end stock +10 and work my way up. I am at +16 and like it alot.
