Headlight knob
Old Oct 27, 2004 | 12:28 PM
damone's Avatar
damone
Headlight ****
I have a 2001 Excursion XLT. My headlight *** broke. The service department tells me I need to buy the switch to get the ***. $84 + change. That's ridiculous.
Anyone have any suggestions?
Thanks,
Old Oct 27, 2004 | 01:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
The headlight switch is under recall. DO NOT pay for one. Go to a different service department or have the one you go to run your VIN for the recall.
Old Oct 27, 2004 | 02:23 PM
damone's Avatar
damone
Man I love this forum.
So although just the *** is broke they will put a new switch on (which includes a new ***)? Will they just give me the switch or will they install also?
Thanks Monsta.
Old Oct 27, 2004 | 03:14 PM
damone's Avatar
damone
When I use **** for a search Iget much better results.
The recall I read was on the 2000 Ex built in Oct. No such luck for me.
Old Oct 27, 2004 | 04:30 PM
ks12ride's Avatar
ks12ride
I have a 2000 and my headlight **** broke also, had to order a new one because my vin wasn't in the recall. The **** was like $25, which is a lot for a piece of plastic, it wasn't exactly the same and had to grind off part of it on the back side. Any way it works just fine and looks more durable (in design) than the old one.
Old Oct 27, 2004 | 05:16 PM
mudman00x's Avatar
mudman00x
i just used a silicone type adhesive it works fine.
Old Oct 28, 2004 | 10:12 AM
damone's Avatar
damone
I thought I could just use an epoxy mix to glue the piece back together, but when I contacted the dealer, just purchased 2 weeks ago, they said they would take care of it.
When I purchased it it needed door lock actuators and a door panel. They were on order and I had just got it back from the dealer after they installed these items when the light **** broke on drive home from work. It was superglued and rubberbanned from previous owner.
So, anyway I am very happy that the dealer is going to take care of this.
Thanks for the replies.
Where did the $25 **** come from? The factory replacement is $84 due to switch and **** come as one.
Old Oct 28, 2004 | 12:45 PM
dougger222's Avatar
dougger222
Mine is broke too. I found a oven **** that works but falls off when pulled on. It looks funny but works.
I'm going to call Ford to see if mine is under recall, it's build date is 12-99 so it may be a December machine.
Boyer Ford in MN (largest parts store around) said $54 for the whole unit.
Old Oct 28, 2004 | 12:52 PM
dougger222's Avatar
dougger222
Dealer list is $69.69 with or with out fog lights same price.
My Nov 29 truck is not covered just got off the phone with the dealership.
Old Oct 28, 2004 | 03:37 PM
ks12ride's Avatar
ks12ride
Don't buy the whole switch. When I looked at the old one vs. the new one, the new one has a lot more support/reinforcement where the old one broke. It's just a bad design from Ford, seems to be a common part between the expy, f150, superduty and excursion. If any one wants the part number, let me know and I'll dig it up when I'm at home.
Old Oct 29, 2004 | 12:52 PM
damone's Avatar
damone
The part number would be good for future reference. the dealer (just purchased 2 weeks ago) is going to take care of it, but it might happen again so I would like to know the part number.
Now, I called a dealer and they told me the part isn't sold sepeartely. Are you saying it is. If so and it is cheap I will purchase it then have the extra switch and **** installed at a later date if needed. I was considering having them mail it to me and install it myself instead of wasting a day at the dealer.
If you had that part number that would be great.
Where did you get yours? How much?
Old Oct 30, 2004 | 12:26 AM
ks12ride's Avatar
ks12ride
The part number is 1L2Z*11661*AA
I got it from Earnhardt Ford in Chandler AZ.
$22.28
It didn't look at all like the old one but it works and hopefully it will last longer than 4 years?
Old Nov 2, 2004 | 11:36 AM
damone's Avatar
damone
Thanks for the info
Old Nov 2, 2004 | 11:45 AM
jdadamsjr's Avatar
jdadamsjr
There's always the "salvage" yards....
How many switches do you think may have been damaged in a wreck
