Transfer Case Problem
Old Oct 27, 2004 | 09:27 AM
cmlind's Avatar
cmlind
I have a Borg Warner 14-56 on a 1990 F150 4.9L M5OD Transmission. The transfer case has been slipping out of gear in 4 high. I thought it was the transfer case until I took it out and now I am not sure if it may be the linkage. The transfer case shifts solid into gear when I have it out. In the truck, however, it is loose. Is there a way to tighten up the linkage or do I need new parts? It seems like all the bolts are tight, but the grooves(or whatever the proper name is for them) on the linkage are loose in 4 high.
