That annoying door chime is finally quiet!
  #76
Old 04-11-2006, 08:36 AM
mueckster's Avatar
mueckster
mueckster is offline
My theory, since I don't have a diagram for the GEM, is that the accessory position is "powering" the chime and the "ground", thru the door switch, turns it on. Removing the "ground" would keep it off.
  #77
Old 04-13-2006, 07:28 AM
mueckster's Avatar
mueckster
I discovered that, while in accessory, the driver's door is the only one that triggers the door chime in the GEM. So, splicing in a switch into the door ajar trigger wire (black/yellow) would kill the chime when turned off. This would allow the other functions of the door ajar switch to work normally, when the switch is on. I was told by Dieselmann that the wire was black/yellow for my truck. Not sure about others.
  #78
Old 04-13-2006, 08:25 AM
PurerockRacing's Avatar
PurerockRacing
PurerockRacing is offline
you have an 01 just like me, I'd think i must have a black/yellow wire as well... I'll be lookin for it
  #79
Old 04-13-2006, 08:55 AM
mueckster's Avatar
mueckster
PurerockRacing,
You should be able to verify if this is the correct wire by grounding a test light and probing the wire. It should make the chime come on in accessory with the driver's door shut. I haven't looked for the wire yet, but I think I will be able to access it from behind the kick panel where the wires go out to the door. I, then, plan to wire in a mini toggle switch mounted in the dash.
  #80
Old 04-13-2006, 09:01 AM
PurerockRacing
I wonder what else that wire controls other than that chime? I don't care to ever have that chime going off, so a permanent disconnect works for me, but I don't want to disable my dome lights, etc.
  #81
Old 04-13-2006, 09:13 AM
mueckster's Avatar
mueckster
I am pretty sure, if you disconnected it permanently, you would affect your dome lights. This wire is the "signal" to the GEM that door is open. I only want to cut off the "signal" while I have the radio on and the door is open.
  #82
Old 04-19-2006, 04:28 PM
RodbusterGS's Avatar
RodbusterGS
RodbusterGS is offline
The seat belt chime "code" worked on my 2001...It took a couple tries to get it right, though!!
Greg
  #83
Old 06-09-2006, 03:55 AM
PtownBubba88's Avatar
PtownBubba88
PtownBubba88 is offline
I have a 2002 Ford F250 SD, I assume the original post on killing the chime also applies to my truck.
My preferences:
lights on chime is ok
Seat belt chime - don't want
key in,,, door open chime- really really don't want, it looks like cutting the blk/pink wire to ignition switch is the quickest/easiest, and if you would "ever" want it back, a simple butt splice takes care of that ,,, correct ?
  #84
Old 06-09-2006, 04:49 AM
JOE-M's Avatar
JOE-M
JOE-M is offline
Yes, this will work on your '02. It did on mine.
Joe
  #85
Old 08-25-2006, 12:39 PM
Lonewolftx's Avatar
Lonewolftx
Lonewolftx is offline
'06 Model Update . . .
The '06 has the Blk/red tracer wire attached to the column itself, at the top where the cylinder slides in.
Just unclip it and let it hang in there, no more chimes!
  #86
Old 08-26-2006, 10:56 PM
John7894's Avatar
John7894
John7894 is offline
That's an easy one. When the chime sounds because the belt isn't being worn simply push the seatbelt release button. It'll silence the seatbelt chime until the truck is started the next time.
  #87
Old 08-27-2006, 06:41 AM
Orezona's Avatar
Orezona
Orezona is offline
Also, in you manual it gives directions for disabeling the chime.
  #88
Old 02-01-2007, 03:07 PM
tumbleweed2's Avatar
tumbleweed2
tumbleweed2 is offline
Originally Posted by cookie88
It does not work on the earlier ones (2001's included ) however, we can simply push the release button on the seat belt latch and it shuts it off for that drive cycle......or unplug it.
I must have a later 01' cause I was succsesfull at turning off the seatbelt chim with the sequence of "on off on off stuff". I'll send you my instructions if you would like to try them out! to turn it off.
  #89
Old 10-10-2008, 06:50 PM
cowboylukas's Avatar
cowboylukas
cowboylukas is offline
Examining the black/ping wire you will see that it comes up to a small horseshoe plastic retainer that fits onto the bottom of the lock tumbler housing like a set of dentures. Simply slide it out of it's groove and wrap it up with a bit of electrical tape and stash it under the tumbler housing.
I have circuled what I found in my truck. I am having problems taking out the horseshoe plastic retainer. I am also not sure if this is the right thing. Can someone help me out on this? Thanks.
99 Ford F-250 7.3L 4X4
  #90
Old 10-10-2008, 06:59 PM
SolidGround's Avatar
SolidGround
SolidGround is offline
Save yourself a bunch of time and heartache...
cut the wire and quit screwing around, Dan got outta control on this one, the modern-day version of this 'mod' is to cut the black wire with the pink tracer...
Quick Reply: That annoying door chime is finally quiet!
