1986 e150 runs rough / will not shift
Old Oct 26, 2004 | 11:31 PM
Aliastwo's Avatar
Aliastwo
Cool 1986 e150 runs rough / will not shift
new to the forum and could use some diagnostic advice.
1986 E150 w/351 4bl/carb auto trans.
Runs rough unless you apply gas at high RPM. Once moving the transmission will
not shift gears. So far completed the following:
Converted air conditioning, replaced water pump, carb, tune-up.
After this work was completed the engine ran great for about 1000 miles. Now it is back to the rough running and not shifting.
Thanks for the advice in advance
Old Oct 27, 2004 | 06:30 AM
TheWiz427's Avatar
TheWiz427
Which transmission do you have? Perhaps the modulator line if it has one is off.
Old Oct 27, 2004 | 06:50 AM
Aliastwo's Avatar
Aliastwo
Transmission is a C6. Line look fine. Modulator replaced 6000 miles ago.
Old Oct 27, 2004 | 10:58 AM
fordr2fast's Avatar
fordr2fast
Thumbs up
Pull the vacuum line off the modulator. If thans fluid is dripping you found your problem replace the modulator.
Old Oct 27, 2004 | 12:49 PM
Kemicalburns's Avatar
Kemicalburns
tranny may need serviceing or adjusting. as for the motor check plug wires, timing and fuel filter
