I have a 93 ford splash 4.0..when i step on the gas you here the engine rattling. when youget the truck going faster through the gears the rattling goes away. Any sugestions
Check the heat shield around the muffler for looseness brought on by corrosion. If it is an engine noise, you may want to try a tank of premium fuel. Good luck.
>sugestions
>sizln6
I've got a 93 SC with the same motor and problem. I've eliminated some of it by running 92 octane. I think it has something to do with the DIS engine.
