Leaf Spring
Old Oct 26, 2004 | 10:13 PM
Karellen's Avatar
Karellen
Question Leaf Spring
I was wondering if leaf springs off an f250 would fit on my f150?
Old Oct 26, 2004 | 10:15 PM
RR4E's Avatar
RR4E
Measure them. It will depend on over-all length, but most important, length between the mount points. You might be better off using an add-a-leaf kit if you're looking for heavier springs. Otherwise, direct replacements are not all that expensive.
Old Oct 26, 2004 | 10:17 PM
mustange70's Avatar
mustange70
IF you are set on it they will as long as your truck is a 4x4 cause 4x4's use a 3" wide leaf spring and that is what the F-250 use.
Old Oct 26, 2004 | 10:23 PM
RR4E's Avatar
RR4E
Have to check and make sure the length is still correct for mounting points. The arch could be different to allow for more load/less leafs etc.
Old Oct 26, 2004 | 10:28 PM
mustange70's Avatar
mustange70
They are same, on the light duty F-250's anyway, I had to help my dad do the rear springs on his 80 spray truck (4x4 f-150) and we used a set of springs off a light duty F-250 4x4 to replaced the ones that were sagged out and bent just before hangers on both sides.
