I just bought a '63 F100 and the guy said it was last on the road in 2000. He said the engine was rebuilt but hasn't been run since 2000. What do i need to do to before I start it the first time. It looks to be complete except for the air cleaner assembly. It is a 292ci with a 2bbl carb.
An excellent penetrant, way superior to WD40 and clones. Most parts stores and even WalMart carries it.
Kroil is another one but not available around here.
Also remove your valve covers and pour oil over your rocker shaft and rockers and valve guides, after nearly 5 years, theres no sense in cranking it with dry guides, as this will cause a little harm.....Janet
