Sponsored by: Kumho
pitman arm problems?
Old Oct 26, 2004 | 04:58 PM
hubdeep's Avatar
hubdeep
I have a 1998 F150 with a 5" lift with 36" tires on it. The problem that I am having is every time that I take it out on the trail I pound out the pitman arm bushing. I have tride all the brands that I can think of and it still happens. Will a steering stabliser help or is there an aftermarket pitman arm out there. If you can help thad be grate.
Old Oct 26, 2004 | 05:40 PM
chuck641's Avatar
chuck641
are you running the stock pitman arm? if so you need to get a drop pitman arm which will put the bushing back at the stock angle which will end that problem.
