Holley fuel pump pressure
Old Oct 25, 2004 | 11:26 PM
bored-68-ford's Avatar
bored-68-ford
Arrow Holley fuel pump pressure
i installed an aftermaket tank, and i installed a red holley fuel pump, it looks like it might over fill the carb, should i get a pressure regulator or restrictor
Last edited by bored-68-ford; Oct 25, 2004 at 11:28 PM. Reason: messed up the format
Old Oct 26, 2004 | 08:52 PM
baitmaster's Avatar
baitmaster
pump info
I have the Red pump on my '72. The instructions say that it is internally regulated pressure. 7lbs, I believe it said. You could put a regulater on it, I had one of the adjustable ones that would go from around 4 to 9lbs. Sounds more like a carb float adjustment or needle valve prob.
