E350 6.0 conversion
Old Oct 25, 2004 | 09:58 PM
XinOK's Avatar
XinOK
E350 6.0 conversion
I need to replace my '03 4x4 6.0 Ex with something that will also haul 6 or 7 people several times per month and then load up with window, door, and cabinet samples, sometimes pull a boat, and hit 65k-70k per year. I need 6000 gvwr and I am thinking about a E350 6.0 conversion van. Question? Why is the torque and HP so much lower on the E350 6.0 than the Ex or SD? Is the 6.0 and 5 spd built the same with the difference being the programing? Has anybody been on a long ride in a 6.0 E350, is the noise level more or less than the Ex or SD?
Old Oct 25, 2004 | 10:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Oct 26, 2004 | 03:59 PM
XinOK's Avatar
XinOK
E350 6.0L Does it have an intercooler?
I have seen this answered every way possible. Does anybody know for sure? Is it a mistake to get the 6.0L in an E350 Chateau and possibly increase the power and not worry to much about heat and noise.
Old Oct 26, 2004 | 04:54 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
I can't honestly tell you about the noise level, but the reason the power is lower is simply because the intercooler and a few other engine externals are smaller/nonexistant on the van for space reasons. The engine is also slightly detuned in order to reduce heat- the smaller cooler and radiator cannot handle the heat input generated by the truck tunes.
They still run great for a van, however.
Old Oct 26, 2004 | 08:40 PM
mark bondlow's Avatar
mark bondlow
I have a e-350 6.0 and the noise level is not bad. at low speeds you can tell its a diesel, but it is not bad inside if you get the carpet and head liner pkg. at higher speeds it is a lot quieter. The reason for less hp is that there is not much room for airflow around the engine and it runs very hot. the engine barely fits in the van. I would hate to have to work on it, you can't get to anything. The van has plenty of power as is and should be good for what you need.You also can carry more in a van than a pickup truck sometimes. why don't you go test drive one before you decide, you may like the van.
Old Oct 26, 2004 | 10:01 PM
XinOK's Avatar
XinOK
We have owned 3 E150 conversion vans but really like our 03 Excursion 6.0L because it never feels overloaded or underpowered. Problem is I need to get in a new ride by 12/31/04 and Excursion SUV doesn't qualify according to accountant. I can't find a E350 6.0L to test drive in Tulsa, but I am now hooked on Ford diesel and 5 speed. Thanks for your comments.
Old Oct 27, 2004 | 02:56 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Get a reg cab 6.0l long bed, and tell everyone to get in the back, and hold on tight...
fishintheobx
Feb 3, 2012 03:20 PM
Ford4Life7.3
Jan 15, 2012 07:52 AM
Misky6.0
Oct 18, 2010 08:19 PM
6.0 PSD 4x4 VAN
Oct 7, 2004 12:44 AM
6.0 PSD 4x4 VAN
Sep 28, 2004 09:26 AM
