backfire
Old Oct 25, 2004 | 05:55 PM
wagon burner's Avatar
wagon burner
backfire
i have a 87 ranger 2.9 liter fuel injected with 198000 miles on it and it started backfiring espicially when going down a hill coasting
any ideas
thank you
Old Oct 25, 2004 | 07:12 PM
rangerboy21's Avatar
rangerboy21
The first thing I would do is check to see if there are any computer codes since these models don't have a CEL. I would also check to see if the timing is set.(10 degrees BTDC)
Old Oct 25, 2004 | 07:16 PM
wagon burner
thank you i will try that
Old Oct 25, 2004 | 08:57 PM
hreed's Avatar
hreed
Several things can cause backfires. The easy checks are for vacuum leaks and cylinder compression. If both of those are good you probably have more serious problems. Keep us posted.
