shoulda left it alone
Old Oct 25, 2004 | 07:33 AM
motorheadmach1's Avatar
motorheadmach1
ok last weekend i pulled my upper intake off to fix an injector o-ring, and while i had things apart i decided to replace the throttle position sensor. aparantly i did that wrong. the idle is a little high, and the biggest problem i onlt have about half power. truck runs well at idle when i open up the throttle it hesiates, alot. and when im driving if i put the pedal on the floor it has what sounds to me like a backfire through the intake and seems to have a bit of a lean misfire. how do i calibrate the tps or whatever i have o do to make it work?
Old Oct 25, 2004 | 07:10 PM
motorheadmach1
anyone know, or knwo where i can go to find out. id hate to take it to the ford dealer they want too much money.
Old Oct 26, 2004 | 06:28 AM
Chrome77's Avatar
Chrome77
Check to see if it is adjustable, most replacements are. If I remember correctly when you hook a digital VOM to it, the output voltage at closed throttle should be 0. if not, adjust until it is.
Chrome
Old Oct 26, 2004 | 08:44 AM
motorheadmach1
thanks ill give that a try tomorow
Old Oct 26, 2004 | 05:56 PM
locknkey's Avatar
locknkey
You may still have a vaccum leak if the idle is too high, check your rubber hoses and around the intake.
