Sponsored by: Real Truck
telescopic mirrors
Old Oct 24, 2004 | 10:31 PM
jasonlasvegas's Avatar
jasonlasvegas
telescopic mirrors
My F-350CC4X4PSD has the smaller mirrors and im not very happy with that. I found a few sets of the telescopic mirrors on E-BAY but they are only for 2002 and older. Has anybody bought aftermarket mirrors, do they fit well. the only reason they wont work is they wiring harnes so that shouldnt be a problem.
also how hard is it to remove the mirrors in the first place
Thanks in advance.
Old Oct 24, 2004 | 11:13 PM
Keeseter CO's Avatar
Keeseter CO
Red face
Thanks in advance.
I don't see how you drive it without them.
I"ll ask a buddy of mine that had his replaced.
Old Oct 25, 2004 | 07:32 AM
HeavyAssault's Avatar
HeavyAssault
The swap is VERY easy, just remove the door panels, remove the mounting hardware, etc. What year is your truck??
Old Oct 25, 2004 | 07:38 PM
jasonlasvegas
Im sorry Its a 2004. bought it used so i had no choice.
I think the wiring harness changes from 2002 to 2003 from round to square plugs
Old Oct 27, 2004 | 11:52 AM
mitch4166's Avatar
mitch4166
If you buy the Ford mirror kit it comes with everything to switch them over.
Old Oct 27, 2004 | 12:16 PM
2003PSDF2504x4's Avatar
2003PSDF2504x4
I think the kit is $400. It's worth every penny. You can't drive safe w/o them. I see these awesome lifted truck with the small mirrors. I don't understand. Why does Ford put these piece of junks mirror on the trucks. If you order the King Ranch mirrors they are color match to your truck. Sweet.
Old Oct 28, 2004 | 04:12 PM
Hoosierdaddy's Avatar
Hoosierdaddy
I just replaced my small mirrors with a set of factory heated/telescopic Ford mirrors new in box for $300 from Ebay. Sold my old ones for $50 on Ebay. The mirrors mount the same from 1999 to present-just the wiring changed. The newer ones also added running lights and color matched paint. The harness is the same-plugs changed. My mirrors came with adapter plugs. Took about 45 minutes total to swap mirrors and add wires in my doors for heat.
Directions are posted on this site. So simple a 10 year old kid could do it.
Old Nov 20, 2004 | 09:22 PM
homey1's Avatar
homey1
Originally Posted by Hoosierdaddy
I just replaced my small mirrors... The mirrors mount the same from 1999 to present-just the wiring changed. The newer ones also added running lights and color matched paint. The harness is the same-plugs changed. My mirrors came with adapter plugs. Took about 45 minutes total to swap mirrors and add wires in my doors for heat.
What did you connect the heat wires to? Did your truck come with heated mirrors?
What brand was the kit you bought? I am curious because I did not think mos came with adapters for the older plug. I really need to update my mirrors. Help!
Old Nov 21, 2004 | 05:18 PM
crummy trk's Avatar
crummy trk
Just thought I'd throw this out there. Whould newer trucks like mine An 04 already have the provision for the wiring for the heat in the harness?
