Hi
Old Oct 24, 2004 | 12:57 PM
Rexpedition's Avatar
Rexpedition
Hi
Looking for help with my 97 Expy 4wd 5.4 idling rough
Old Oct 24, 2004 | 07:56 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
ENJOY FTE
Scroll down to the Expy forum, (main page) and post your question there
Old Oct 24, 2004 | 08:11 PM
buzzard's Avatar
buzzard
Is it only at start-up or always? Do you have a "check engine" light on your dash illuminated? The more details you give, the better chance for a proper diagnosis, although sometimes it's impossible to diagnose through the net.
It's probably a bad IAC valve or a bad coil pack but could be countless other things too.
Old Oct 25, 2004 | 09:43 AM
Rexpedition
Thanks
Thanks for your reply.
That was my first time to this site.
I really just meant that as a "hello" message, not a problem to be diagnosed.
Of course, if I needed a diagnosis, I would provide a long list of details.
I was mainly trying to search for an answer and it seems I found one.
You were quite close - not the IAC valve, but the 90 degree elbow hose below/behind it was melted/deteriorated all the way through.
Replaced it with a $5 universal "Help" brand hose from Kragen's and it's purring like a kitten again.
This info I found at this site was quite helpful and I think the key was that I had codes PO171/PO174 and P1131/P1151 which, when showing up in pairs like that (errors from both banks at the same time) it's a pretty big likelyhood that the problem lies ahead of those codes and I was able to focus on the possible causes under the hood (instead of the typical o2 sensor).
Next up - PO446 Evap problem (had it for a long time with no noticable consequence), but that will be for another day.
Jerry.
