no spark
Old Oct 24, 2004 | 11:18 AM
remmers's Avatar
remmers
no spark
i was driving down the street and my truck starting doing what it was in for a few weeks ago running really bad, well they replaced the cap and rotor and it fixed the problem. Well today i am driving down the street and it started again, so i get home i take off the cap and rotor and check for cracks and water, well nothing, i put it back on and now i have no spark. I have cked the coil tested the coil and nothing where else do i look for spark
its a 93 f-250 351 4 x 4 115,000 miles
thanks
Rich
Old Oct 24, 2004 | 11:36 AM
Egor's Avatar
Egor
Are you sure you got the rotor back on right? Don't mean to be a smartass, but I've actually forgot to put them back in.
Old Oct 24, 2004 | 11:51 AM
remmers's Avatar
remmers
yeah and i went as far as going and buying a brand new cap and rotor just to be safe and nothing
Old Oct 24, 2004 | 03:42 PM
remmers's Avatar
remmers
ok i replaced the cap rotor and ignition moduale and i tested the coil and it is good and still no spark???
Old Oct 24, 2004 | 04:02 PM
gearshift101's Avatar
gearshift101
No spark
I just had the same problem on my 87 f 350, I replaced all tune up parts and still had no spark. I then noticed that I had a bad connection with the coil connector. Then I removed the coil connector and use jumper wires and connected them from the connector to the coil itself, and whala spark.
hope thats the fix...good luck
AL
Old Oct 24, 2004 | 05:43 PM
remmers's Avatar
remmers
i check all fuses and the fuel pump fuse was blown replaced that got power to coil but no spark replaced coil and im driving thanks
