door locks
Old Oct 23, 2004 | 07:59 PM
Bubba50's Avatar
Bubba50
door locks
I have a 2000 explorer and i am haveing trouble with the key
i can insert it into the door locks but it will not turn on either lock >??
Also i am getting a error code that says (running lean on left bank ) can any one tell me what needs to be replaced ??
Thanks guys
Old Oct 23, 2004 | 09:29 PM
jonm61's Avatar
jonm61
As far as the locks go, they just need to be lubricated. This is a very common problem on the X. Use a graphite lube...they're available at any hardware/home improvement store, any locksmith, and probably even Walmart/Kmart.
As for the error code, from what I've been told, when it's only one bank, it's probably the O2 sensor, but I'm not sure which one is which.
Old Oct 24, 2004 | 07:38 AM
Bubba50's Avatar
Bubba50
Will a bad o2 sen cause the truck to idle real ruff when you first crank up in the morning ??
