1978 - 1996 Big Bronco
Inertia switch, do you see a problem if......
Old Oct 23, 2004 | 06:15 PM
ALSAIR's Avatar
ALSAIR
I wire my aftermarket fuel pump relay threw the stock inertia switch??? The fuel pump instructions say to to wire it to a oil pressure switch, so when the truck is in a accident and engine is shut down, the fuel pump will shut off. Strictly a safety issue. Well I don't have the stock E.F.I. set-up anymore. I have a carb set-up. But a wreck is a wreck, a rollover is a rollover, and the stock inertia switch will still do it's job. Am I missing something?????
Al
Old Oct 23, 2004 | 07:04 PM
Str0ud's Avatar
Str0ud
Unless it specifically says not to use the stock inertia switch that's what I would use. Alot of those aftermarket parts come with some pretty basic instructions.
Old Oct 23, 2004 | 11:54 PM
greystreak92's Avatar
greystreak92
I agree. We all know what the inertia switch is designed to do. Might as well use it as it was intended to be used.
binzer
Jul 19, 2012 11:37 PM
geckocub69
1997 - 2003 F150
Jul 1, 2007 04:46 PM
patho44
Feb 25, 2007 11:57 AM
cbjr61
Aug 3, 2005 01:43 PM
