I have an 03' F350 with 17,000 miles and the painted front bumper has a fist size hole with the paint chipped off. Any time I get the truck washed the problem seems to get worse. I was wondering if anyone else was having a proble like this? Would this be covered under the warranty? I did not hit anything as there is not a dent or scratch.
I also have a 2004 f250 with 17,000 miles and have had a few small chips I assume from gravel etc. I've never seen the dealership since I bought the truck last December and I have been touching up with paint myself.
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
actually, yes....
but in my "defence" it was in the middle of a parking lot and was just the narrow post with no sign on it ....
was just turning right with a blind corner to the left so I never saw it
just pushed it over at idle and barely felt anything
I am pretty sure if you take it back to the dealer with the "I have no idea how this happened" line they will warranty it. I took in my '02 with 46k on it and the front bumper,grille and step bars were rusting. They did a good faith replacement on them which I thought was very generous of them. That is one of many reasons I bought an '05.
After doing 3 years at a Ford dealership bodyshop as the parts manager I would say GO FOR IT. I've seen some ridiculously stupid things replaced under warranty--a peeling NON DAMAGED front bumper should be easy. As much trouble as they have with factory painted parts this should be easy. If your dealer balks--see another one. I've even seen bed mats replaced for "wrinkles" on high-end trucks, door seals, the list is endless. It's more up to your dealer than anyone. Don't let them repaint it--make them replace it. There's still nothing quite like that finish--it's really a good process when done correctly.
