gas tank sizes needed
Old Oct 23, 2004 | 12:01 AM
fordf150316's Avatar
fordf150316
Question gas tank sizes needed
hey everyone. i know that this has probably been asked before but i couldn't find anything about it. what i need to know is what size tanks my 1988 f150 long bed truck has. i bought it used and on the rear tank i have a bad leak and the front tank leaks if over half full. all switch over valves pumps etc. working fine. i need to order new tanks and not sure if i need a 16, 17, 19 gal tank. all places i have inquired about a tank have asked for the three sizes i have listed and i do not know. any help would be appreciated
Old Oct 23, 2004 | 12:04 AM
fordf150316
sorry guys i forgot to say it is 300 inline six engine also
Old Oct 23, 2004 | 04:46 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Longbeds have 19 gallon tanks. Shortbeds got the smaller tanks.
Old Oct 23, 2004 | 10:31 AM
fordf150316
thanks socaldesertrider. thats what i needed to know
Old Oct 24, 2004 | 08:59 AM
jroehl's Avatar
jroehl
Don't know about '88, but my '90 F150 rear is 18.2 gal (front is 19.0). You probably could put a 19 on....do you want to chance that it doesn't fit?
Jason
Old Oct 24, 2004 | 10:39 AM
aging_F150's Avatar
aging_F150
My '87 5L/302 engine Supercab w/ long bed has a 17 gal rear and 19 gal forward.
Old Oct 24, 2004 | 12:59 PM
mike L's Avatar
mike L
Fuel tank size
I have a 87 f150 4.9 and my owners manual says 19 gallons for the rear the only choice ????
Old Oct 24, 2004 | 06:09 PM
aging_F150's Avatar
aging_F150
My manual shows a footnote for the SuperCab long bed indicating a revision to 17 (actually it says 17.5 gal). Maybe yours was made before the revision was printed and maybe they were installing 19s in the rear before that? I don't know. I am the original owner and I know what the manual that came with mine says. Also, when I run the rear tank to near dry and refill it takes about 16-17 gallons. The front takes about 18 under the same circumstances.
Old Oct 25, 2004 | 02:01 AM
V8 Andy's Avatar
V8 Andy
i think the mainly indicator for the bigger tank is the wheelbase... i have a long bed but only a std cab, and i ask one from JC W. and he said that it is the short wheelbase e.g. 133" .And i have the "little" front tank. So now i´m a little bit confused !
<<´92 f-250 >>
Old Oct 25, 2004 | 11:12 AM
mike L's Avatar
mike L
Gas tank sizes
<<´92 f-250 >>
Did you get a tank? I have a 87 f150 4.9 efi std cab, with long wheel base ( 8' ) and my front tank is a 19 gallon. I replaced it 3 months ago. Try autozone or vip etc. Did they try your vin number to match the tank size, might help?
Old Oct 26, 2004 | 05:34 AM
V8 Andy's Avatar
V8 Andy
Hi,
no i didn´t it yet.
the vin not include the size tank, i read the WB 133" from the door sticker.
i think autozone has no tanks for me, but i´ll look again for it.
Are the 133" really the "short" one ?
oh i´m searching for plastic tanks...
Old Oct 26, 2004 | 09:09 AM
mike L's Avatar
mike L
fuel tank sizes
Hi,
no i didn´t it yet.
1987 f150 4.9efi standard cab long bed. Call ford with your vin number, thats what i had to do because my owners manual listed both sizes for my front tank. I have an 8' bed wb 133 with a 19 gallon front tank. My front tank measures 59" long from flang to flang. Autozone says its between the 16 and 19 gallon tanks for your truck and my truck. There someone on FTE that just bought a poly fuel tank. try an advance search above for fuel tanks. Measure the length of the tank.
www.autogastanks.com have plastic fuel tanks
Under Fte search i found:
"42" is 16.5 gallons fuel tank
58" is 19 gallons
I have a 91 F150 XLT Lariat E4OD longbed."
Old Oct 26, 2004 | 02:14 PM
V8 Andy's Avatar
V8 Andy
Hey,
your link from www.autogastanks.com is not working.
*smile* the search button is back ... i´ll search for more info.
But i found something on the i-net, if the truck has a regular cab, the 133" wheelbase is the long one, if there´s a super cab, the 137" is the short one..... is this right ?
Damn, I throw the tank away.
Is the distance of the straps for the tank different, too, or is it the same ?
I prefer plastic tanks, because the shipping to Germany will be a little bit cheaper :-) I hope so....
Old Oct 26, 2004 | 03:20 PM
andym's Avatar
andym
Check out my post in this thread: https://www.ford-trucks.com/forums/s...d.php?t=285600
Old Oct 27, 2004 | 12:34 AM
V8 Andy's Avatar
V8 Andy
hey, ok
thanks, i have a 16.5 gal tank, and the similar poly tank has 17 gal.
i find them on "i need parts.com" ...
Ok thanks again
Andy
