Computer Chips & Tuners
superchip problem??????
Old Oct 22, 2004 | 07:09 PM
Black Refer's Avatar
Black Refer
Just got my superchip progremer today, started to hook it up,
-disconected fuel pump.
-Plugged it in to the truck, with ignition off.
-It told me to hit the > when ignition was off, did it.
-then told me to turn ignition on, but not the truck. did it...
-then it kept flashing between "turn ignition on" and "do not start engine". Every minute or so it would beep once and continue with the same message.
I waited 7 to 8 minutes, and it continued to flash with the same instructions.
I unplugged the module and started over again. But the same thing happened. Can anyone help, I think I might just be a little retarded, and can't read directions, but I reviewed them 3 times, and can't find any error in my process.
Thanks,
Black Refer
Old Oct 22, 2004 | 07:11 PM
WhëëlMå1's Avatar
WhëëlMå1
Moved to Computer Chips and Tuners forum
Old Oct 25, 2004 | 10:09 PM
FTE Ken's Avatar
FTE Ken
Are you 100% certain you're turning it to the on position, and not just the electrical accesories position? Also, what vehicle?
Old Oct 26, 2004 | 12:46 PM
Black Refer
YES IA AM TURNING IT ALL THE WAY TO THE ON POSITION. i ALSO STRIED IT IN THE ACC. POS. iT IS AN 04 F150 3V.
Old Nov 1, 2004 | 10:51 PM
kevhunt's Avatar
kevhunt
I have the same engine, and I didn't have to disconnect the fuel pump. The instructions say to disable the fuel pump *only if you are prompted*
The Programmer didn't prompt me to disable the fuel pump. Installed the 87 octane program without a problem...Kevin
