ignition
Old Oct 22, 2004 | 06:22 PM
drz400gncc's Avatar
drz400gncc
ignition
i have the 1st generation of the tfi modules. i am using the engine for a power unit. this mod only has 3 wires and i need to know were they go. (green) (white) (red) i know the red goes to mod back to coil and the green goes to the other side with a jumper that goes back to the ignition switch but where does the white wire go.
Old Oct 22, 2004 | 07:31 PM
Franklin2's Avatar
Franklin2
What kind of set-up is this(year, engine, etc.). If the distributor does not have a vacuum advance with a connection for a vacuum line, then the ignition will not work properly without the computer and the other sensors that came with the engine. If you don't have a vacuum connection on the dist, your best bet is to get an older duraspark II dist and ignition box that does not require a computer for timing control.
Old Oct 22, 2004 | 09:27 PM
drz400gncc's Avatar
drz400gncc
its an 81 escort engine. it doesnt have a computer its the 3 wire tfi the first one they came out with.
Old Oct 23, 2004 | 09:52 AM
Franklin2's Avatar
Franklin2
Here's a diagram. Looks like yours is the one on the left.
http://www.autozone.com/images/cds/g...3d8011f7d2.gif
Old Oct 24, 2004 | 07:07 PM
drz400gncc's Avatar
drz400gncc
thanks thats what i needed.
