my pronlem is my headlights work fine but my emergency lights and turn signals don't when i turn the emergencies on only one of the fuses makes a clicking sound and i have switched them around and both fuses are good just no power to it and when i use the turn signal nothing happens the lights on the dash don't even indicate what direction is there a special fuse for this
yes sorry i meant the flasher is it the round metal piece with two spade terminals on it i found two wire behind the gauge cluster that are red with a yellow stripe and both have a inline fuse on of them is hooked up but i can't find the rest of the other where does this go
Check out the ARTICLES section right here at FTE! There's a detailed article on how some guy fixed his turn signals. I'm not gonna go into detail, but all roads (&wires) lead to turnsignal switch. Do yourself a favor, READ THIS ARTICLE!!!!
i have a problem with the lights on my truck i can't get the front turn signals to flash the back ones do but the passanger side of the truck both front and back lights are dim but the brake lights and flashers are fine just the parking lights are dim
Pull the bulbs and check with a test light for current in the front turn signals. If you have current, test or replact the bulbs. If no current, check and clean the grounds for the lighting circuit. Park lights may need a ground check also.
