Sponsored by: Auxito
4x4 not disengaging
Old Oct 22, 2004 | 11:12 AM
shotgunner426's Avatar
shotgunner426
4x4 not disengaging
Having trouble--98 f150 will engage and everything engages into 4h but sometimes will go into 4low---after everything turns o.k. then front wheels and drive shaft will not disengage unless you turn off the motor....Is there maybe a relay that is staying energized somewhere..... Thanx
Old Oct 22, 2004 | 11:37 AM
kingfish51's Avatar
kingfish51
With it engaging okay, I would look at 2 main things. On the firewall, passenger side, high up near the hinge are 2 solenoids. One of these will engage the front diff, which is working fine, and the other disengages the front diff. Either the disengage solenoid is bad or you have a vacuum leak between there and the front diff. I doubt if it is the vacuum motor on the front diff, as you are engaging it fine. I can't remember which solenoid disengages the diff, but I would look for a cracked or broken vacuum line first.
junkyardbates
Feb 11, 2011 08:37 PM
zrt600guy
Dec 1, 2009 09:36 PM
rsylvstr
1997 - 2003 F150
Jan 30, 2008 06:50 PM
index_case
Bronco II
Feb 13, 2004 02:11 PM
