Bronco II Ford Bronco II
problem (help)
Old Oct 21, 2004 | 03:41 PM
jimmy_9019's Avatar
jimmy_9019
Question problem (help)
ive been driving my bronco II now for about 3 weeks and everything has been fine up until i drove it to work and then i pulled into the parking spot and it just shut off and then it wouldn't start back up, i heard it could mabye be the alternator but im not sure? please help thanks jimmy
Old Oct 21, 2004 | 03:50 PM
mrshorty's Avatar
mrshorty
Can you be more specific about what it does/doesn't do? Does it not respond at all to the key? Does it try to start? Lights/radio or anything else work?
Old Oct 21, 2004 | 07:51 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Also the year, etc.
Old Oct 27, 2004 | 03:53 PM
jimmy_9019's Avatar
jimmy_9019
it sounds like it wants to start, just bought new battery so its not that?
Old Oct 27, 2004 | 06:13 PM
mrshorty's Avatar
mrshorty
So, the starter will crank the engine strong, but the engine won't catch and run.
1st question: Is the engine getting fuel? This is best checked with a fuel gauge at the fuel rail. If a gauge isn't handy, can you hear the fuel pump (or pumps, depends on year) run breifly when you turn the key on?
2nd question: Is the engine getting spark? Quick to check with a timing light.
Old Nov 14, 2004 | 10:22 PM
onestrangebroncoII's Avatar
onestrangebroncoII
ever time my beast did this.. the problem was that stupid fuel interuptor gadget that is mounted on the floor of the passenger side at the top left hand edge of the end of the carpet. its alittle black box about the size of a cigarette pack with a white button that resets it... when this thing goes out it knocks the power out to your electric fuel pump and your dead in the water mine finally shorted out and i just by passed the whole thing.... i may get soaked with gas and burn up in a crash but my truck starts....
good luck
Jimmy Cash
New Member Introductions
Jul 13, 2016 03:02 PM
INASTR8LINE
Apr 21, 2016 04:39 PM
RUNVS
Mar 30, 2012 08:37 PM
RyanGruhn
1978 - 1996 Big Bronco
27
Aug 25, 2008 03:28 PM
Jimmy Dean
3.8 & 4.2L V6
Jun 16, 2004 06:01 PM
