Idiot? lights
Old Oct 21, 2004 | 11:28 AM
roozter's Avatar
roozter
Question Idiot? lights
Hello! I am not that new to FTE, but new to Diesels. I have a 2003 6.0 FX4 Crew Short bed Lariat. I have read a lot of the topics here, and have read some things about changing air filters, draining water, etc before the light comes on. Maybe I am an "idiot" but I was impressed when I read the diesel supplement that the truck could actually tell me when this stuff needed to be done before it caused big problems. However, it seems these lights are just the diesel versions of the idiot lights on gas vehicles?
What is the consensus? I know this will probably get people going on both sides of the fence but I am curious about ya'll that have used the lights to tell you when to perform maintenance. Have you run into larger problems because you didn't put your maintenance on a schedule but rather waited for the light?
Thanks for all your great info and advice!
Old Oct 21, 2004 | 11:56 AM
jwdeats's Avatar
jwdeats
I doubt if you get people on both sides of the fence. I hope everyone is on the side of the fence that believes maintenance is performed on a schedule determined by mileage (and/or time). Waiting for the lights to come on before performing preventive maintenance is a ridiculous notion.
Draining the water is easy. So is checking the air filter indicator. Surely you aren't too lazy to get on your back and turn a screw or pop the hood and look at a guage? Only an idiot would wait for the idiot light to come on before following scheduled maintenance. This forum amazes me.
Old Oct 21, 2004 | 12:19 PM
roozter's Avatar
roozter
Ok, ok. I suppose I asked for that. I being new to a diesel was impressed (shouldn't have been) that the vehicle could alert me to changing an air filter or draining water. I guess I assumed (we all know the result of that) that new technology had made its way into these diesel vehicles (for example, you can control your entire house from your pc and set alerts for just about anything you want). IMO, the "idiot" lights on any vehicle could be set in a manner to be useful, i.e. more sensitive or based on a ratio of good/bad things happening. Since the supplement talked about a ratio of air flow triggering the air filter light, I again assumed that these lights were actually useful.
Thanks for your input!
Old Oct 21, 2004 | 12:42 PM
jdadamsjr's Avatar
jdadamsjr
call me an idiot then !!!!!!
The water in light never came on in my 7.3 and I never drained it...
Have only done it once on my 6.oh only because the light came on
(turned out to be the HFCM fix that many have gone thru....)
Sorry,
being in the technology business - if something is there to tell me something I use that something and worry about more urgent things to me.... I have quite enough things to fill my time without introducing others
Course, it is MY truck and so I can do what I want to mine and you can do what you want to yours...
And I won't take a hard line on you're being **** about following some guidelines in a book and I'll continue to drive mine like I want....
that is until the UN decides it's not in my best interest to do that and tells me otherwise... (oh, but that's not until after 11-02-04)
Old Oct 21, 2004 | 01:01 PM
roozter's Avatar
roozter
Thanks JD! I was looking for your info as well. Not sure which route I will take. Probably checj it periodically but not change anything till the light comes on and see if it goes within my acceptable parameters.
You said it right, we all have our own trucks, and to each their own!
Old Oct 21, 2004 | 01:03 PM
kw5413's Avatar
kw5413
Gees boys...feeling a little testy today are we?
Old Oct 21, 2004 | 01:12 PM
jdadamsjr's Avatar
jdadamsjr
HEY YOU !
YOU WANT TESTY !!!!!!!!!!!!!!!!!!!!!!
it's PMS time around the household AND trying to finish a house AND trying to close the loan...
but, I did put the requisite smilies and bouncing happy icons
Old Oct 21, 2004 | 01:37 PM
kw5413's Avatar
kw5413
Hey JD...Don't whine to me about PMS at your house. I've got four alien female humanoid species and one female pup at my my house. (See, even makes me st..stutter). Two of which are TEENAGERS.
So there...take that!
Sorries to roozter BTW for thread theft.
Old Oct 21, 2004 | 01:45 PM
jwdeats's Avatar
jwdeats
In the interest of full disclosure, I am an idiot because I am currently relying on my water light. I haven't checked it in a while because I've never found water so far.
Old Oct 21, 2004 | 01:59 PM
jdadamsjr's Avatar
jdadamsjr
Me either....
sorta like asking the wife if somethiings wrong....
She'll tell you !!!!
Old Oct 21, 2004 | 02:40 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
I could use a date with a good Texas girl
Either one of your daughters planning a trip to NC anytime soon?
Old Oct 21, 2004 | 02:44 PM
kw5413's Avatar
kw5413
PSD...Gonna bring your girlfriend?
Old Oct 21, 2004 | 02:47 PM
SpartanDieselTech
Former Vendor
What girlfriend...
Back to the subject, IMO no "damage" will be inflicted by allowing the check fuel water light to come on; it is only a level gauge, and has quite a large margin of error. You would have to drive it for a good while with the light on before any water would be actually contracted into the fuel system.
Old Oct 21, 2004 | 02:58 PM
kw5413's Avatar
kw5413
Yep young friend...same old story. Same old result.
Truck.
Girlfriend.
Truck.
Truck.
Truck.
Looking for new girlfriend.
Truck.
Grow old and alone with GREAT truck
Old Oct 21, 2004 | 03:03 PM
SpartanDieselTech
Former Vendor
Truck.
Girlfriend.
Truck.
Truck.
Truck.
Truck.
What bugs me...is that even when you use your time for girlfriend over truck, it is still not enough...nothing will ever be enough.
I would be in luck if girls had fuel/water seperator drain plugs and oil filters to solve your issues
