bagging the front
Old Oct 21, 2004 | 12:22 AM
arsetard's Avatar
arsetard
bagging the front
i plan on buying a 67-72 f100 and bagging it. should i stick with i beams and get drop ibeams and i beam bad brackets, or should i convert it to a mustang 2 front end? if i decide to do the m2 conversion where id a good place in socal to get a decent deal? has anyone dealt with scotts hotrods in ventura? how are their prices?
Old Oct 21, 2004 | 08:41 PM
arsetard's Avatar
arsetard
anybody??
Old Oct 21, 2004 | 09:36 PM
1972ford_f-100's Avatar
1972ford_f-100
ok man,depends on how much money u gots,if u got about 1500 go for the M2 conversion,if u dont,go for the i-beams,depends on ur miney situation
Old Oct 22, 2004 | 08:55 AM
arsetard's Avatar
arsetard
im willing to spend more to get better results in the long run. worse comes to worst i could always sell it for more if i do the swap. i was woundering if anybody had done it either way and how it came out. i want to lay rockers or atleast frame but i dont know if i could with i beams
Old Oct 22, 2004 | 02:27 PM
1972ford_f-100
ok,it can be done with i beams with major changes,the easiest way to lay her in the weeds is to do the M2 swap,but i guarentee u will never get out of it wut u put into it money wise,i buaght my truck for 600 and already have over 2 grand in it and i have had it for about 5 months or so,but im doin it for the fun and i will never sell it.....
Old Oct 23, 2004 | 08:02 AM
arsetard's Avatar
arsetard
about how much am i lookin at spend each way?
Old Oct 23, 2004 | 12:19 PM
1972ford_f-100
i believe,depending on where u go,its about 1600-2300 dollors for the M2 conversion,and ur i beams are about three hundred for each or a pair,but if u need any help on anything just ask,i got enough parts megizines to kill a horse,lol
Old Oct 23, 2004 | 12:35 PM
Azguy54's Avatar
Azguy54
Baggin? M2 conversion? Mind "splainin" it to me? Never heard these terms before.
Old Oct 23, 2004 | 01:09 PM
RR4E's Avatar
RR4E
Baggin, where I come from anyways, means driving the living hell out of it. But in this case, it apparently means lowering it. The M2 conversion is referring to installing the rack and pinion steering from a Mustang II onto the front end. It's a pricey little venture, and it will lower the truck as well as offer more steering feed-back, and control, but doing it properly will make it work reliably. I've seen way to many such conversions done half right...which is simply done wrong in my books. Either buy a complete kit, or stick with the I-Beams. One thing I'll say, my 69 4x4 was a wonderful truck, and I only sold it because the gas prices became to high to afford to drive it anymore. Had a .060 over 390, dual pattern rv cam, ported intake and heads, reworked 2 bbl carb(would side-hill at near roll over angles without missing a beat) and pass pretty much anything but a gas station with the 10:1 flat tops...between the cam/compression ratio combination alone, it ran only on premium...when gas hit 1.07 a liter...I had to sell it...
Old Oct 23, 2004 | 02:47 PM
1972ford_f-100
ok,baggin-replacing the springs in the front with air bags,and making it easy to lower and raise perrty much where u want it,and also can replace the rear suspention with a four link and airbags
M2-mustang two conversion,where,bluntly,u cut off ur front end and replace it with a IFS(independent front suspention) designed like the old mustangs came with,it replaces ur tierod(i think)steering with rack and pinion,(just my opinion,but i would rather stick with trusted tierods then switch,i have had tons of trouble with rack and pinion),lowers ur front by 3 inches just by adding it,and it gives u an easier way out to add bags
Old Oct 24, 2004 | 10:09 AM
Azguy54's Avatar
Azguy54
Got it now, thanks guys. Won't be doing that to the '68, just makin it a real nice runnin street truck resto-mod.
Old Oct 24, 2004 | 02:18 PM
arsetard's Avatar
arsetard
im doing the same thing but its going to ride and handle 100x better also i will be able to get the exact stance i want.
Old Feb 20, 2009 | 08:50 AM
1967ford100's Avatar
1967ford100
ok i got a ? whats the M2 conversion
Old Feb 20, 2009 | 09:58 AM
jsutton's Avatar
jsutton
Mustang 2. Putting a Mustang 2 type suspension on the front. Like from Heidt's or Fatman Fab.
P.S. It must have took some searching to find a thread 4 1/2 years old. LOL
Old Feb 20, 2009 | 11:33 AM
Ford 67 Ford's Avatar
Ford 67 Ford
Got a question, there are a lot of Crown Vic front end swaps going on lately so how does that swap compare to the Mustang swap as far as ride, handling, durability and ability to bag the front end the best. Later.
