65 Overdrive-Need Solenoid Color Code Help!
Old Oct 20, 2004 | 11:37 PM
GregTruck's Avatar
GregTruck
Anybody out there know which wire goes to which on the 65 Ford Warner Overdrive Solenoid. The harness has two blue wires. One has a yellow stripe I believe. There are two colored wires coming out of the solenoid. Does it matter which way they go? I dont want to blow anything. I imagine these solenoids are expensive...
Thanks
Old Oct 21, 2004 | 02:45 PM
bigdav160's Avatar
bigdav160
I've only seen a couple of those OD units. Perhaps this link will help you:
http://www.classictruckshop.com/club...over/drive.htm
Old Oct 21, 2004 | 05:13 PM
MyDads64's Avatar
MyDads64
The website referenced can be a bit confusing, as the author did a real "customizing" of his OD controls. He does have a diagram of the original controls, but it is difficult to read.
IFF the 65 OD wires like my 64 OD, the solenoid should have a blue and an orange wire coming out of it.
The blue wire connects to the blue wire from the overdrive relay.
The orange wire connects to the blue wire with orange stripe from the kickdown switch.
good luck
aardvark
1997 - 2003 F150
34
Jan 5, 2017 07:31 AM
mnmsutton
Nov 14, 2014 12:49 PM
storchmj
Mar 25, 2014 01:21 PM
nothercrash
Mar 10, 2014 08:57 PM
cbr900
Aerostar
Feb 20, 2005 03:14 PM
