engine/transmission swap
Old Oct 20, 2004 | 10:34 PM
bill1958's Avatar
bill1958
Hello to all. My question: 1986 F-150 2wd with a 300 inline six and an auto transmission. Will this engine/transmission go into a 1980 F-150 4wd that has a 300 inline six and manual 4-speed transmission? Both engines carburated. Wondered about connections at transfer case and driveshaft. Of course will switch steering columns too. thanks to any replies
Old Oct 21, 2004 | 05:57 AM
Steve's Beast's Avatar
Steve's Beast
Welcome to FTE!
The motor will go in but your auto transmission will not. You will have to get a auto tranny from another 4X4 or use your 4 speed.
Steve.
Old Oct 21, 2004 | 10:05 PM
63redtudor's Avatar
63redtudor
One thing that you will find as well is that the ignition/carbs on the 2 motors are a bit different. The '80 300 will have the druaspark 2 & the '86 will have the TFI & a feedback carb (there's a slim possiblity that you have the first EFI, but unlikely). Do yourself a favor & switch the '86 over to the duraspark 2 & non-feedback carb. If you're going with a different intake/exhaust, still go with the duraspark 2. You're '80 F150 will be set up for it. Duraspark is the better (& simpler) system.
