1979 F150 Window Rubber Install help
Old Oct 20, 2004 | 09:13 PM
RumpityRump's Avatar
RumpityRump
Hi and THANKS for your help.I already have the rubber/felt inner and outter pcs. There were no instructions or maybe there were not suposed to be.Do I need to remove the glass on the doors or is there another way of doing this?
Old Oct 21, 2004 | 06:46 AM
towtruck's Avatar
towtruck
I tried to install mine without removing the glass but couldnt get it. I unbolted the glass and let it slide to the bottom of the door. Piece of cake after I did that.
Old Oct 21, 2004 | 04:52 PM
theonlybull's Avatar
theonlybull
i sprayed a little wd-40 between the rubber and the track, then kept working the rubber down, and cranking the window down at the same time..... did have to pull from the bottom for the last little bit..
Old Oct 22, 2004 | 10:58 AM
wannan4x473-79's Avatar
wannan4x473-79
I just put new doors on mine...the weatherstrip was easy without the glass in place. taking the glass down is simple...no need to get cut all to pieces tryin to weasel the channel and anti-rattle pieces in
