pedal swaping
Old Oct 20, 2004 | 08:53 PM
rancherman84's Avatar
rancherman84
pedal swaping
does anyone know if the pedals(mainly the clutch pedal,master and slave cylinder) from a 89 f-250 4x4 diesel will fit in a 92 f-250 4x4 diesel?
my 92 has the E4OD and i have found a 89 with the ZF5 for about 500 bucks with a bad engine but good trans and such.i'm thinking of doing a trans swap but need to know what parts will fit where.
Old Oct 21, 2004 | 12:14 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't know if it is true for the heavy trucks, but my '87 pedal assembly is different than the pedal assembly in my dad's '92. I don't know how long the design from '87 lasted, and when the newer design began, so I don't know for sure that they are different, but there is a good possibility that they are.
Old Oct 21, 2004 | 08:25 AM
FordPerf300's Avatar
FordPerf300
I got a 93 clutch pedal assembly you can have if that one does not work out.
Old Nov 18, 2004 | 04:47 PM
F350Lee's Avatar
F350Lee
I'm interested in that if you still have it. Is it the entire assembly? clutch, brake, and gas? I need to go out to the garage and see exactly what mine looks like. I have a 94 F350 with a C6 right now and am gonig to a manual.
Old Nov 19, 2004 | 01:02 AM
FordPerf300
The gas pedal is seperate, this is just the clutch and brake. Your brake pedal should come right out and this goes in it's place.
Old Nov 19, 2004 | 05:20 AM
jroehl's Avatar
jroehl
I'm guessing the pedals changed from '91 to '92 with the slight redesign of the front end of the trucks. I've got a '90 F150 and a '93 F250 (both autos), and the pedals are different.
Jason
Old Nov 19, 2004 | 11:07 AM
F350Lee's Avatar
F350Lee
Right, I just looked at mine last night. I'll buy it from you if you are interested in selling it. Should I PM you?
