code 122-have question
Old Oct 20, 2004 | 08:17 PM
olderguy's Avatar
olderguy
Question code 122-have question
94 F150 302 with 119K shows code 122 Throttle position sensor below minimum voltage. Location looks like it would be difficult to change. Anyone changed one of these? Are there any adjustments on it? I am average DIY owner. Should I do this? Any help appreciated. Truck runs good with CEL on.
Old Oct 20, 2004 | 08:53 PM
WALJON's Avatar
WALJON
YOU have to take the throttle body off the plenum it isn,t hard just take your time there is no adj. two screws hold it on when you get to it good luck
Old Oct 20, 2004 | 11:03 PM
4x4lowandslow's Avatar
4x4lowandslow
Yeah, I just replaced mine not too long ago. I think the new one is bad and the old one was good. But enough about me. Tis' very easy to change with basic tools. Like stated above, you will need to remove your intake hoses and the front of your intake plenum. Be sure to get a new gasket before you disable your truck. $2 gasket. I hate engineers because they obviously don't work on the vehicles they design.
Old Oct 21, 2004 | 01:27 PM
olderguy's Avatar
olderguy
Thanks for quick reply and help. I'm encouraged. Feel I can do that.
