Sponsored by: Real Truck
Superduty abs problems
Old Nov 4, 2004 | 08:01 PM
steamer1234's Avatar
steamer1234
Correct you do have 4 wheel ABS. Do a search here in superduty and you should find all you want about removing and cleaning your sensors. Check your ABS wires carefully to make sure they are not damaged. Good luck.
ABS .
Old Dec 12, 2004 | 02:34 PM
jwsilkie's Avatar
jwsilkie
Read all the good info you guys provided. Was having the same problem with the ABS and cx engine lights. Changed the ABS sensor, problem resolved. By the way, this is a 2000 SD witha 7.3 with 112k miles. Thanks.
Old Dec 12, 2004 | 03:11 PM
99f350sd's Avatar
99f350sd
Originally Posted by steamer1234
You only have front ABS if you have wires running to each of your front wheels, If you do not you have RABS. Which would mean you only have one sensor in the rear{top}that I know about. The FORD dealer carries this sensor for around $22.00. On 2000 F250 4x4 , 4wheel ABS was an option. I don't know about other years. It may be standard on the Fx4.
No such thing as just front abs. Either you have rear wheel or all four.
Old Dec 12, 2004 | 03:20 PM
RobertJohn's Avatar
RobertJohn
I had the same problem and it was the VSS located on top of the rear diff.. cost $21 to replace and all problems went away.
My brake petal would go to the floor, the pulse even while in park. But the VSS fixed it.
Old Dec 12, 2004 | 04:32 PM
etcetera's Avatar
etcetera
Autozone will read codes for free.
Erio
Old Dec 12, 2004 | 06:27 PM
TOPFLOR's Avatar
TOPFLOR
superduties have 4 wheel abs, but a 3 sensor system
Old Dec 12, 2004 | 08:26 PM
99f350sd's Avatar
99f350sd
Many have just rear wheel abs.
BIGBAND39
Escape & Escape Hybrid
39
Mar 24, 2016 12:23 PM
northernleitz
Dec 3, 2014 07:24 PM
Paul Larsen
2004 - 2008 F150
Sep 8, 2013 10:18 PM
osage
15
Aug 16, 2012 07:54 PM
goose213
1978 - 1996 Big Bronco
Nov 22, 2004 03:12 AM
