another post about this is a day or so old, but yes, you can.
motor mounts loose ,also trans mount, jack up engine, curse a lot. drink some beer.
look for other post. i just went to the oil section when if irst got on this forum and went thru all posts until i found what i wanted. also go to 460 engine section.
look for other posts. i just went to the oil section when if irst got on this forum and went thru all posts until i found what i wanted. also go to 460 engine section.
it helps to have drive up ramps. i would replace oil pickup screen and maybe oil pump.
