Fuel pressure
Old Oct 20, 2004 | 12:05 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Question Fuel pressure
Can anybody tell me how to check the fuel pressure? Thanks in advance!
Old Oct 20, 2004 | 04:58 PM
2000psd's Avatar
2000psd
1. Relieve the fuel system pressure. open the gas cap and the drain valve on the fuel filter ( grab a container to collect the fuel )
2. Remove the fuel line from the fuel pump and attach a fuel pressure gauge betweeen the fuel pump and the fuel supply line to the engine.
3. Turn all accessories OFF and swith the ignition key ON (engine not running)
The pump will run for a few seconds. Note the reading on the gauge.
Old Oct 20, 2004 | 05:17 PM
Quadzilla's Avatar
Quadzilla
It's a lot easier than that on an original body style truck. Remove the engine cover, and you'll see a shrader valve, (tire valve) on the side of the fuel pressure regulator. Start the truck, with a tire pressure gauge, (which is wrapped in rags) check the pressure. You should be in the 60-80psi range. You probably aren't so you'd be wise to shim it.
Get back to us with your pressure, and someone will walk you through the process.
Old Oct 21, 2004 | 12:10 PM
94 1/2 stroker
I wont get to work on it till saturday so I'll let ya know this weekend about the pressure. What is this shim you are talking about? Is this a simmple mod? Thanks for the info!!
