plug choice?
Old Oct 19, 2004 | 09:46 PM
grumpy44's Avatar
grumpy44
plug choice?
This is the engine. 351w, w/30 over flattops, comp cam/500 lift, ported & polished stock heads w/trickflow spring upgrade, ported & polished performer intake, 670 cfm carb, BBK swap headers, Mallory hyfire ignition w/ promaster coil. other odds and ends. You'd think plug choice would be easy. should I go with 1 or 2 hotter than stock. or will it burn right with the stock plugs. Any Ideas? thanks
Old Oct 20, 2004 | 08:45 AM
smoke n tires's Avatar
smoke n tires
i like ngk plugs. ive had problems with bosche and the autolites dont seal as well as the ngk with the crush washers. i would try the type of ngk the autoparts lists
