water pump woes
Old Oct 19, 2004 | 09:04 PM
smoke n tires's Avatar
smoke n tires
water pump woes
has anyone had problems sealing a water pump on a 302? ive done mine about 5-6 times, tryed all different methods and sealers. it still leaks. i also noticed some copper or brass looking pieces in the coolant overflow, could this be from the radiator? i was very nervous when i saw them, this is a heathy new 302 with about 3000 miles on a complete rebuild. ive also tryed a different pump and the timing cover was swapped as well. any help would be great..
Old Oct 22, 2004 | 04:30 PM
hflu's Avatar
hflu
New gaskets and just a little silicone around the water channels should do it. Some people don't use any silicone, and too much can definitly cause leaks because it actually prevents the gaskets from seating. Use a torque wrench (not sure on ft/lbs) in a criscross pattern to make sure each bolt is tightened equally. Where is the leak coming from? Did you install the water pump backplate with a good gasket?
Old Oct 23, 2004 | 09:31 AM
smoke n tires
yes its a good felpro gasket. it leaks on the bottom between the plate and pump. i have a habit of using to much silicone, thats problably my problem.
